Moving this thread to the boiler room where fellow Kuuma owners can chime in.
I think they are all creosote makers.
That's the problem, you think but you don't know. You have owned two really crappy furnaces, of which I would NEVER even think to put in the basement of any house I or any loved ones of mine own. Another big problem at least with the two I had, was if you lost power and the blower couldn't run, they will go nuclear on you. No air between the burn box and the outer cabinet.
Show 'em that pic of the inside of your chimney...That's the problem, you think but you don't know. You have owned two really crappy furnaces, of which I would NEVER even think to put in the basement of any house I or any loved ones of mine own.
Or install an emergency heat dump door...that can be done on almost any wood furnaceThat's because you purchased ones which were not rated for gravity flow. This is again a decision you made. If this was a concern/problem of yours you should have purchased one which was rated for gravity flow OR install a battery backup/generator system.
no my liner has a tee on the bottom with a collar that comes out flush to the outside of the chimney and my stove pipe connects to that probably 2" or 3" into the collarIs the stove pipe entering to deep past the thimble in the chimney?
Well I guess Im just a awful person. Thanks for pointing that out, Im sure someday you'll be man enough to respond to people with out being a complete jerk
). Just mis-informed.I have a central masonry chimney in my house with a clean out hatch. I didn't put a ash cap on the bottom of my liner as there's no way I could reach up in there to ever remove it for cleaning. so with a flashlight and mirror I am able to look all the way up my chimneyJust curious how your looking up the chimney if it’s attached to a liner.
I have the same setup...only on an outside wall. What I did so that I could cap the tee and still clean it out was to have the bottom of the tee crimped, then clamped a short section of liner onto it, just long enough to get down to the cleanout door. The cap can then put removed through the cleanout door...I keep a brick under the cap to make sure it can't come off until I'm ready.I have a central masonry chimney in my house with a clean out hatch. I didn't put a ash cap on the bottom of my liner as there's no way I could reach up in there to ever remove it for cleaning. so with a flashlight and mirror I am able to look all the way up my chimney
I like to use wax paper as a release on the surface that I want the silicone to not stick to...have had good luck with itYou can make a basic seal by putting a bead of silicone around the rim and then closing the door on it
Luckily I've become paranoid and watch it like a hawk for about 20 minutes every time I load it up. When it does take off I cut air off and it starts to cool down.
When I am loaded up and running my stove probe reads between 400 and 450 on avg. when it gets down to around 250 I know it's just coals and it's time to load it up again. But if I take too much time putting wood in the temps on the thermometer skyrocket until I shut the whole stove down. It only happens when I open the smoke bypass tho. If it's open along with the door and that thermometer reads 300 it takes off on me even if there is only a minimal amount of coal in the firebox.
The fire doesn't have to be burning at all for it to happen. Even if I have coals in the firebox it still happens. To clarify I mean the stove pipe temps skyrocket and I cut the air out to choke it off. This is when I use a mirror and flashlight to look up chimney to verify I don't have fire transfer into the chimney liner. What I usually see is a small clump of smoldering embers where the stove pipe attaches to chimney liner.
I'm just trying to figure out if my stove pipe is the cause or is my furnace damaged in some way that might cause this kind of stuff.
You are correct, I am indeed meaning chimney fire. I played around with it the last couple days.The thread is a bit confusing. Title pretty well says chimney fires - but also from posts it sounds rather like strong draft is sucking firebox fire into the smoke pipe when the door/bypass is open. Maybe also creating some secondary burn in the smoke pipe - truly dry pine would be pretty flammable.
My old boiler used to do that (not the secondary thing), I had to watch it when the wind was gusting outside. It had a pretty direct path from the firebox to the smoke pipe.
I use a spot eater to clean my chimney and flue, I ran it up and down 3 times both up the chimney and stove pipe.
Not much spot in chimney or stove pipe. Maybe a pop can full out of the stove pipe.
But I was indeed experiencing a fire inside my stove pipe.
That's a real good point, glaze will puff up like popcorn when heated to a fairly high temp, and then if it is not taken to a temp that will ignite, it will just kinda glow...I have played around with the propane torch before, heating creosote chunks that were cleaned out of the chimney...just to see what it was like when it starts burning (it is actually kinda hard to light, and doesn't stay burning real well)(but this is only outside of a chimney situation...inside a chimney I'm sure it acts totally different, due to the column of preheated air blasting past...)The only way that you would produce a chimney fire after a few days of cleaning, would be if you had glaze deposits which weren't removed during brushing
