I have a problem with my stove and I can not correct the issue. I have sealed the ash pan as directed, it is vented into a standerd block chimmney. The vent is 4 feet tall with two 90's. I have tried pellets from TS and Hammer Premium with no noticable differance. The burn pot fills up with carbon. Three days on heat level four leave about 2" of crust in the pot with holes all the way through from the draft. If I pull the pot and turn it upside down the whole mass falls out as a brick. The Hammers leave a much harder crust that requires scraping. The only way it seems to burn properly is with the heat level set on 3 and the draft set on 9. It burns about 3 bags per day this way. Even running it this way it requires cleaning every other day. Any thoughts would be apreciated.
Thanks.
Thanks.
