My daughter recently bought a house that came with a King 5502M pellet stove. The unit appeared to not have been cleaned in a long time and was full of old pellets. I methodically went through all areas of the stove and cleaned out all of the fly ash, as well as the burn pot, exhaust port, air inlet and inside of the back of the stove. I also removed all of the old pellets and vacuumed the hopper and auger area. I added new pellets, plugged in the unit and the display indicated Hr-3 and the led next to Auto above the mode button was flashing. I could hear the exhaust fan cycling on and off, and then the auger started and began to fill the burn pot. Unfortunately, this process continued with the cycling of the fan on and off and the pellets feeding until the the burn pot overflowed. The pellets did not ignite and when I removed the burn pot, the ignitor was not even warm.
I thought I had a bad ignitor, so I ordered up a new one and replaced it today. Started the stove back up and it went through the same cycle as above, but never ignited. I checked the new ignitor and it was cold to the touch. I am not sure what to check next? I looked at the board and noticed it had 2 glass tube fuses, but they both appeared to be intact.
Like I said previously, I am not sure what to check next, so if anyone has any suggestions, I would greatly appreciate it.
Thanks in advance.
Thanks in advance.
