cleaning except for the "brass port inside firepot" (it says it could be clogged)
Pull the hose off the vac switch and blow throw it (into the stove)
If air goes through it then it's not plugged. Then again blowing through it could unplug it
Pull the hose off the vac switch and blow through it (into the stove)
Yes that is how you jump the pressure switch, after jumping if exhaust fan runs correctly that means one of two things, bad switch(doubtful as it is new) or you have a vacuum leak that you will have to track down. That could include the exhaust fan gasket, plugged venting or door gasket. Jumping the switch will let you know the problems is vacuum or not.Do I just join the two connectors that connect to the round pressure switch?
Got to admit, my first inclination was to install it with the bead of sealant wet to make a nice, real strong bondTake and run a bead of Red RTV around the perimeter of the flange AND PUT IT ASIDE AND LET IT SET UP FOR A WHILE and then install it. That way when you remove it at a later date (and you will), it will come apart easily.
The switch is supposedly new but I have doubts that it really is new.Yes that is how you jump the pressure switch, after jumping if exhaust fan runs correctly that means one of two things, bad switch(doubtful as it is new) or you have a vacuum leak that you will have to track down. That could include the exhaust fan gasket, plugged venting or door gasket. Jumping the switch will let you know the problems is vacuum or not.
It would make me wonder if someone returned a faulty switch and then they sold it to you. Are there any numbers on the switch. Should be 80549 and are you attaching hose to the grey port?Would it bother you that a new one has a couple of markings like someone making sure they installed it the right way round
Got to admit, my first inclination was to install it with the bead of sealant wet to make a nice, real strong bondI'm glad I waited.
'Nuther one that bit the dust I suspect. Like Lake Girl moderator, she has been absent for a couple years, must have drowned. Kap and are are about the only 'old timers' left.You could try to PM this guy hasn't been on since May 2019 but he is a 5502 guru:
https://www.hearth.com/talk/members/owen1508.32330/
Read threads both state pulsing is normal not sure that is right, also talk about air wash on door:
https://www.hearth.com/talk/threads/useless-pellet-stove-king-5502.150707/post-2037207
https://www.hearth.com/talk/threads...el-5502m-im-having-issues.116001/post-1614960
I know this is old but, after having an unrelated problem with our stove and doing some repairs, I ran our 5502M through the self-test and perceived the same "problem". I did some searching and found this post. I joined the forum just to respond (I'll probably be around - these things are fussy). Somewhere in our house we have a manual. I couldn't find it and the only thing I could find, online (fast), was for a 5500M. They look identical (the 5500 and the 5502) and I presumed the self-test indications were identical. I just got off the phone with Kelly, a tech person at the factory. She seemed very knowledgeable and said, "Oh, THAT MODEL (the 5502m) does that - it ramps just a little and cycles about every two seconds......". She said that I should run the test, and, on that first test (for the exhaust fan) walk around and open the glass door on the front. She said the fan should, then, come on full. Great. The weekend just passed and I ordered on exhaust fan on Ebay, for 75 bucks, last night. I did what she told me to do and, of course, it worked just as she'd described. If you have a 5502M and it does what you originally described in your question, that's what it's supposed to do.Hello,
We have a 5502M coming on for it's fourth year of operation.
We put it through the self-test and the exhaust fan is not working properly. It's supposed to turn on full and then reduce to a level just above the minimum pressure switch setting according to the manual.
Instead of turning on full, it tries to spin up (we have the panel off on the right-hand side as you look so I can see it moving a bit) and gets to what I guess would be about 1/10th of what it should be before spinning down and trying again. This repeats every two seconds or so until I move on to the next test.
Any idea what this could be? I took the fan off and cleaned out the ash/soot from inside the housing and the fan spins freely when pushed by hand if that makes a difference.
I'm by no means an electrical expert but I do have a multimeter so can I remove the fan and test whether the connectors are receiving the right power from the control board? Or is this likely to be something else entirely?
Thanks for reading
5502M manualSomewhere in our house we have a manual. I couldn't find it and the only thing I could find, online (fast), was for a 5500M.
