Now that's confusing. I thought when you open the door it burns faster, not slower?
The in-rushing room air will cool the stove and the hot flue gases will go up the chimney. You would be converting your stove into an open fireplace.
... many stove burn like an open fireplace when their front doors are open, with a slow, gentle fire.
Exactly. The range varies a lot according to who has tested kiln dried lumber, but an average is about 12% according to building science corp. When OMNI labs tested 2x4s and 4x4s that had acclimatized they were getting 18-20%.
Charles 2 is correct. Kiln dried wood may come out of the kiln at 18 percent, but, once it sets around, in the wood pile for a while, it will absorb moisture from the air, and it will attain the same moisture content as any other wood in the wood pile.
I found this out the hard way. I ordered a truck load of kiln dried Southern Yellow Pine, tongue and grooved, to make the ceiling for a log house I was building. I had the rafters up, and was going to nail the t and g pine on top for the ceiling.
The wood sat out for a week or two before I could get it installed, this in the humid air of central Georgia.
I installed the ceiling. Several months later, the house was finished. I cranked up the wood stove and that wood started to get skinny on me. The tongues were 3/8 inch wide, in many cases, the tongues pulled right out of the grooves. So that, a 1x6 shrank a half inch!
Odd, I thought GA was a pretty humid location. What is the source of the data?
Is that dangerous to do without a screen?
Same as a fireplace: sometimes you can get away without a screen, but best to use caution. Especially when burning softwoods, which I find much more likely to crackle and pop and toss embers out of the fireplace on onto the hearth (or floor, or rug, or furniture). But once a fire is down to coals very little popping and shifting of logs occurs.
Does anybody make screens for wood stoves?
That's funny, I was there, I installed the roof, and I watched the boards shrink, in some cases 1/2 inch. Now. y'all are telling me it didn't happen.
I was mistaken about one thing, they were 2x6s not 1x6s.
I did use wood from the same sawmill for the floors of that house, t and g yellow pine 1x6s, kiln dried. Same thing, the boards set around for a week or so, under roof, before I could install them.
I didn't realize how much moisture they would absorb.
Months later when I fired up the wood stove, each board shrunk at least 1/8 inch. So, there was at least a 1/8 inch crack between the boards, in some cases more than that.
I learned the hard way, kiln dried wood will absorb moisture from the air.
