My BK woodstove experience is very boring on a typical day to day basis. I need something to spice up our relationship to keep me interested in her.Way to complex for me. With the meters and gauges.....I just watch the fire, itll tell you what it needs. Im an old head.
Try this. It worked for me.Got the magnehelic installed. Looks like im cruising around .12 WC
Also, since I have the new Iphone it seems the pics I take are too large to upload now. So that’s cool.
Thanks for the tip ill have to give it a try next timeOops. I was just shown another option.
I was looking in the photos app directly, but…
In the forum’s post:
-Attach files
-Photo Library ( at bottom of page when attaching a pic)
-Options
-Select Size
Just in case someone catches it and wants to complain….yes, this manometer is actually hooked up in the reverse of how directions say to hook it up (supposed to read on the red side of the scale).As you can see a damper is critical for some with tall stacks.
View attachment 321249 View attachment 321250
I really like the ones with a 0.25"WC scale, as most chimneys won't ever peg that, and they're easy to read in 0.01"WC increments. My stove spec's 0.05"WC nominal, and 0.06"WC maximum, so getting a gauge with a scale much greater than 0.25"WC makes it hard to read that fine.Hey guys, I'm setting up a Grandma bear and I'm looking at the magnehelic gauges on EBay. I'm wondering what range to get. Looking at the numbers you guys are using I'm thinking a Dwyer 2000-00, but will the 8" flue cause more draft or less, or will it not make a difference?
and I see there's a new old stock one for 25.00/8 shipping... and I likey the zero set knob, seems fitting for a 40 plus year old stove... and thanks Ashful, thats the range I was looking at too.The Dwyer Mark II model 25 works well...it will work fine on a 6 or 8" flue, no huge difference there to the gauge...
I just drilled a hole and stuck the copper tube through...but some that want something a little fancier have bought a 1/4" NPT/compression fitting which will "thread" into the pipe if you drill the right size hole, and hold your tongue just right.Thanks for the warning, I'll let my wife knowThe Mark II is on it's way. So when I go to install this I should use a piece of copper tubing same ID, and how far should I go in? Four inches like a flue temp gauge or just like a 1/2 inch? Can I epoxy a nut on the DW Pipe so i can thread it in like an O2 sensor bung? Just thinking of maintenance and trying not to elongate a drilled hole after time. Seems to me this would keep a good seal, or maybe it won't matter, because of the double wall being a little leaky anyway. I'm thinking I'll give it a gentle bend and aim it upstream to help keep it clean. How much does the placement matter? I have the damper right on the stove, then a 30 degree bend with about 52 inches of straight pipe into the return 30. I read in previous posts to keep it close to the stove, the nearest I could do in that straight pipe would be about 16 inches from the collar.
I must have a dirty mind, because that whole comment seems filled with inuendoJust drill hole sale size as O.D. Black magic marker and mark 2.5” and slide in to the mark. It’s not critical.
Occasionally slide it out and run a pipe cleaner into the copper pipe…do this before it gets dirty. They make soft pipe cleaners and bristle pipe cleaners…grabs pak of each for cheap. Good to go. If you decide you don’t like it, then add a fitting later on.
