hi I was wondering if the 2000 highlander hold more water then the 100 newyorker , I had a 100 newyorker in but if I turn on the heat down stairs it couldn't heat the hold house, so I was looking at buying a 2000 kerr if would do the job.
How much water it holds has little to do with how much heat it will put out. That comes down to heat exchanger & burn efficiency. My new boiler only has to burn 6 hours a day to keep us warm, my old one could hardly keep up burning 24/7 and had to use the oil once in a while. New one holds less water. I think.
This site uses cookies to help personalise content, tailor your experience and to keep you logged in if you register.
By continuing to use this site, you are consenting to our use of cookies.
