I used to have an Austroflamm Integra, and it had no self-igniter. It wasn't long before I got fed up with the exorbitant price for the starter and tried all the methods named above.
Then I discovered how well the torch works. Takes 30 seconds of bending over with the torch, ease the door shut, and in 2 minutes you have a blasting fire. AND it works every time.
Hope that helps.
- Kerosene is quick, but can flash out at you. Needless to say I took that as a sign from God and didn't try gasoline!!
- Same with barbecue starter. Keep in mind both of these methods generate greasy soot which is not so good for the insides of pellet stoves.
- Gel hand sanitizer wasn't available then, so I tried rubbing alcohol. Not enough heat for long enough to get a fire going. The combustion draft would dry it out and snuff it before it would take off.
- Tried breaking up fire-starter cubes, those worked pretty good, but were a PITA to handle, plus I always had to make sure I cut up enough that my wife could start a fire. Plus they really gum up a pair of garden shears.
- The local feed store sells something that looks like fir shavings; those work good but are just as expensive as the alcohol napalm.
Hope that helps.
