True but this also produces the most heat at times.With the damper open, your heat goes up in the chimney. Waste of fuel.
It will require a lot of unnecessary reloads.True but this also produces the most heat at times.
So a damper of some sort is necessary with this stove?It will require a lot of unnecessary reloads.
The stove is designed with the bypass damper, so yes. Typically a pipe damper is used for extreme draft situations.So a damper of some sort is necessary with this stove?
Yes they would not have designed one into the stove if it was not. The manual is pretty clear on it as wellSo a damper of some sort is necessary with this stove?
Ok so what I’m getting at is if the damper puck is indeed warped is my stove completely done or can I get away with installing a pipe damper? Would hate to get rid of this stove mid season.The stove is designed with the bypass damper, so yes. Typically a pipe damper is used for extreme draft situations.
Or be trying to control the stove with it by running it partially closed which would heat it unevenly. I don't know if it is warped or not but running the stove the way he was would do it if anything was going to.I suggest to clean the bypass area first, lubricate and see what happens. The bypass damper is a solid piece of steel 5.5 inch in diameter and almost an inch thick. To get that warped you need to throw a grenade to it.
It would not operate as designed with out the built in damper. You could probably get through with one but it wouldn't work right.Ok so what I’m getting at is if the damper puck is indeed warped is my stove completely done or can I get away with installing a pipe damper? Would hate to get rid of this stove mid season.
I shall see tomorrow. Thanks for all the info.If your secondary combustion chamber is not warped, your damper won't be either.
So it looks like baffle is indeed warped. The damper puck gets stuck while it slides over the top of the baffle. Looks like I’ll be installing a pipe damper.I shall see tomorrow. Thanks for all the info.
Can you post a few pictures?So it looks like baffle is indeed warped. The damper puck gets stuck while it slides over the top of the baffle. Looks like I’ll be installing a pipe damper.
Looks fine from what I can tellYep, been over heated. Unfortunately, the rod on the damper is also the door lock. If you won't use the damper, you need to be careful not to over fire the stove. How does the combustion chamber look like from the front and bottom?
