The EKO brings the tank up to temp. Around 170º Now, as the boiler is on the downhill run, cooling off that is, i've found that if I shut the main circ pump off as soon as the fire is almost out, I can prolong a higher tank temp. If I allow the EKO to shut itself down, FUEL signal, and circ pump shutdown at 140º, it seems to cool the tank down quickly. The Boiler is 90' from the tank.
Does that make sense to anyone ?
It seems that by circulating the water until the pump shuts off is a waste of electricity and stored heat becomes heat loss.
Is there a way to program the controller to shut the pump down after the fire is on the downhill run ?
I think if I can stop the pump at 180º I could have quite a few more hours of stored heat.
Kev
Kev
