I really dont drive at all. My wife does, but very little. Id like to think we are saving emissions by less driving.
I can understand and respect that opinion. The problem I see is that most people who share your opinion really have no basis for comparison. They have never used and usually don't understand modern stoves. And that leads to lots of false assumptionsNow Im lost, lol....all I meant was I like a simple little cast iron stove, nothing more or less. I know mine is basically junk, but it got me thru the winter last year and Im sure it will again. I know nothing about all the stuff on that kind of motor either, im lost.
There are several modern stoves that look like old ones. Moroso jotul and Vermont castings come to mind.Thats very true, I have never been around a modern stove, so I have no clue how to operate it. Im sure I could figure it out quick enough. One thing about modern stoves is they are mostly NICE to look at, and they work for those who own them. My house is very old, our decoration theme for the whole house is Old Country I guess youd call it. Antiques abound at my abode.
The problem I have isn't so much with the stove you have. It's the fact that you don't have a chimney. You have connector pipe. How much will you be saving if you burn your house down because of that?My piece of junk does me just fine. Was 55 in here this morning, got a fire going, it was 65 in about an hour. I appreciate all the concern, but Im juus trying to survive on very little money. I cant afford $3000 to 10000 on a stove and flue. I have about 900 in mine, is it junk? Probably. But its paid for, it works, and itll keep me from Big Oil............
You don't need 2 chimney 90s they aren't even made. You would need a tee, tee support. Wall passthrough whatever length pipe needed a couple wall supports and a cap. Looks like $1000 to $1500 for the lower cost chimneys. Considerably more for premium onesI can have the stove at the top of the "good" range, and the stove pipe outside is barely warm. In my mind, if I keep it clean, ie monthly i should be ok. None of us knows what will happen, if we did we could stop it from happening. Am I on thin ice? You bet, but in all honesty, I cant afford a new chimney. Out of curiosity, how much would a real chimney cost me? Im thinking 1500 to 2000. 2 90 elbows, and about 20 foot of pipe?
Nicely said. I tend toward the same. I get a chuckle out of the threads of people running "firmware updates" on their pellet stoves, but they're probably laughing at the amount of wood I need to process and load. To each their own.I am somewhere in the middle. I don't want electronics on my woodstove. But the simple clean burn options are fantastic.
The cat itself certainly doesn't change anything, but the possibility to shut down inlet air certainly helps one counter excessive draft much better than a stove without this ability. Speaking only for my BK Ashfords, I had no controllability issues with 3.5x the "maximum allowable" draft on one of my chimneys. I could easily get it right down to black box mode from any state, no issue.A cat won't change anything you will still have excessive draft leading to controllability issues.
I understand this sentiment completely. Heck, I wanted to keep most of my fireplaces open when I moved in, even talked about removing the one wood stove that was installed, to get back to an open hearth. And when I did start considering stoves, it was in this "dumb box of iron" mentality that you share with my former self. But a short time of operating (even a relatively poor) modern EPA stove made me realize how much I was missing, in terms of better efficiency, better controllability, longer burn time... and without any new operator complexity.Now Im lost, lol....all I meant was I like a simple little cast iron stove, nothing more or less. I know mine is basically junk, but it got me thru the winter last year and Im sure it will again. I know nothing about all the stuff on that kind of motor either, im lost.
What happens when you have a small. Glass or door gasket leak when draft is that high. I have seen plenty stoves destroyed by that issue and a thermostatic control won't change that. But in that case no one was talking about a blaze king so the thermostatic control doesn't enter into the discussion at all.The cat itself certainly doesn't change anything, but the possibility to shut down inlet air certainly helps one counter excessive draft much better than a stove without this ability. Speaking only for my BK Ashfords, I had no controllability issues with 3.5x the "maximum allowable" draft on one of my chimneys. I could easily get it right down to black box mode from any state, no issue.
That said, there were other problems which caused me to want to correct the high draft. Chief among them were poorer installed efficiency, and fly ash-clogged combustors. But controllability itself was not an issue.
Any stove is designed to turn down to a specific level at a given draft. If you double or triple that draft there is no way you will get proper turndown. Will it overfire? Probably less of a chance of that with a cat stove for sure but there will still be controllability issuesI think it was not a Tstat remark, but the fact that a cat stove (or at least ashfuls cat stove) can dial down the air more than a tube stove. This is because of the EPA regulations that limit turn down to avoid polluting smoldering - but a cat stove can run lower than a tube stove.and still do so cleanly. Therefore the allowed turn down of the air is larger. Hence overdraft is more easily controlled with a cat stove with larger turndown.
I do agree with the 'if leak, then big problems still occur ".
Good point. I was primed for failure, if anything else went wrong, with such strong draft.What happens when you have a small. Glass or door gasket leak when draft is that high. I have seen plenty stoves destroyed by that issue and a thermostatic control won't change that. But in that case no one was talking about a blaze king so the thermostatic control doesn't enter into the discussion at all.
To. Much draft will result in short burn times loss of efficiency and possible over firing. That can damage the stove, the chimney, and cause excessive temps leading to safety issuesJust a question, and I dont want to start a whole thread, but what is too much draft? I guess a waste of wood for one. Im new to this for the most part, so dont mind the newbie question.
There is some inherent danger in it, yes. As @stoveliker said, a good stove and properly maintained, it will stay under predictable control and temperatures.I dont see how packing a stove to the gills, then firing it up, then going to bed is safe? That seems dangerous to me.
