I have found That if i have a good knowledgeable dealer of the products that they sell that i do not have to call the manufacturer to answer questions that the dealer should be able to do. VIgas Boilers Dist by AHONA (made in slovakia)
Pete Schiller said:Effecta produces user manuals and marketing materials in English and you can communicate directly with Effecta employees in English. That overall made me feel much better about getting one of their boilers than say a Slovakian boiler.
henfruit said:I have found That if i have a good knowledgeable dealer of the products that they sell that i do not have to call the manufacturer to answer questions that the dealer should be able to do. VIgas Boilers Dist by AHONA (made in slovakia)
I've spoken to two Effecta owners who have their systems running, one with a 35kW in Michigan and the other a 60kW in New Hampshire. Both of them had nothing but great things to say about their systems. I don't know whether they spend time on Hearth.rpmm70 said:Come on Effecta owners, give us some feedback on these wonderful boilers. I am sure many of the people on this site would like to hear about them.
nrford said:Very pleased with mine! Running since early Oct. approaching 800hrs of run time. Selected Effecta for cost and the fact that Brian was only about an hour and 15 min. away. I figured if I had trouble I knew where he lived! Fabricated my own tanks with a consult from Brian. Did my own plumbing, including doing the underground pipe like the stick,ie spray foamed in the ground. Brian built the control panel. We did have to rework this as we did not get switching controls correct on the first try. I usually fire once per day. On the coldest days I make a small fire before before leaving in the morning. 1000 gallons of storage, 2150sqft home plus DHW for family of 4. I feel my biggest draw is DHW as this is produced by a boilermate. 4+showers/day laundry and dishwasher uses a lot of water! I have burned 8-9 "FACE"cords of wood so far. I figured from Nov.&Dec; gas bill to have save $300 in natural gas. VeryVery happy.
145 at startgoosegunner said:nrford said:Very pleased with mine! Running since early Oct. approaching 800hrs of run time. Selected Effecta for cost and the fact that Brian was only about an hour and 15 min. away. I figured if I had trouble I knew where he lived! Fabricated my own tanks with a consult from Brian. Did my own plumbing, including doing the underground pipe like the stick,ie spray foamed in the ground. Brian built the control panel. We did have to rework this as we did not get switching controls correct on the first try. I usually fire once per day. On the coldest days I make a small fire before before leaving in the morning. 1000 gallons of storage, 2150sqft home plus DHW for family of 4. I feel my biggest draw is DHW as this is produced by a boilermate. 4+showers/day laundry and dishwasher uses a lot of water! I have burned 8-9 "FACE"cords of wood so far. I figured from Nov.&Dec; gas bill to have save $300 in natural gas. VeryVery happy.
What are your typical tank temps start and charged?
How many hours to charge?
How many loads to charge?
Is it in house? Storage location?
gg
nrford said:145 at startgoosegunner said:nrford said:Very pleased with mine! Running since early Oct. approaching 800hrs of run time. Selected Effecta for cost and the fact that Brian was only about an hour and 15 min. away. I figured if I had trouble I knew where he lived! Fabricated my own tanks with a consult from Brian. Did my own plumbing, including doing the underground pipe like the stick,ie spray foamed in the ground. Brian built the control panel. We did have to rework this as we did not get switching controls correct on the first try. I usually fire once per day. On the coldest days I make a small fire before before leaving in the morning. 1000 gallons of storage, 2150sqft home plus DHW for family of 4. I feel my biggest draw is DHW as this is produced by a boilermate. 4+showers/day laundry and dishwasher uses a lot of water! I have burned 8-9 "FACE"cords of wood so far. I figured from Nov.&Dec; gas bill to have save $300 in natural gas. VeryVery happy.
gg
180 at end
4.5-5.0 hr burns 1 load
in room attached to unattached garage about 38' underground run to house.
if I reload after about 1 1/2 hr burn I can get tanks to 193.
nrford said:top of tanks. bottom is within about 3 degrees. All of this has little to do with the performance of the boiler and more to do with how well storage and house are insulated FWIW!
Mine is plumbed into the existing Burnham natural gas boiler. 3 zones, 1 is for a heat exchanger in a forced air handler. 2 is baseboard radiant heat and 3 is the boilermate for DHW.rpmm70 said:How are you extracting heat from your storage? Meaning, are you using a furnace coil, in slab radiant, radiators, etc.....
hiker88 said:If anyone has information or a video about lighting the effecta I would appreciate seeing that. I saw something in the documentation about an electric lighter, and the unit does not appear to have a dedicated lighting door so I'm curious.
rpmm70 said:Very nice, you have a little bit of everything going on there. Have you noticed that anyone load inpaticular, draws the storage down quicker/faster than the others?
nrford said:hiker88 said:If anyone has information or a video about lighting the effecta I would appreciate seeing that. I saw something in the documentation about an electric lighter, and the unit does not appear to have a dedicated lighting door so I'm curious.
Turn induction fan on,Rake residual ashes out so they fall into ash pan in secondary chamber. This will leave charcoal in primary chamber, light charcoal with torch, throw a handful of small(kindling) splits on top of burning charcoal. After about three min. load 6-8 larger splits,2-3" into chamber. Allow temps to rise 35-45 degrees open and fill chamber. Shut it and walkaway, saying "see you tomorrow buddy!"
rpmm70 said:I too have a family of four and my guess is that I will be in the same boat as you. (DHW being the largest draw) but that will come later. I see you have multiple types of H20 heat. Are they installed in seperate areas or both everywhere?
