Well, have been running the stove now for a little over three weeks so thought I would give a little update. I am starting to get use to the air intake lever. (hated it at first) I was having issues with too much air getting in with just the slightest opening of the lever and I am talking only moving the lever 1/16"...just a tap with my thumbnail. I called Woodstock and they agreed that was not right and said it sounded like my chimney was drawing too hard. So I was glad I installed the pipe damper and started using it...has improved tremendously. I hesitated using it because all of the literature I had read said that rarely one was needed. My chimney is only about 12' but I live across from a wide open field and get wind often and have very good draft.
The other issue I was having was when shutting down for the night, I was getting puff backs. After another call to Woodstock, I got to talk to the guy who actually built the stove and has the exact stove in his basement. He told me I have to get the stove temp up to 500º before shutting down. I laughed and told him at those temps I would have to have a naked beach party!
![Smile :) :)](/talk/styles/default/xenforo/smileys/grin.gif)
It worked, no more puff backs. I knew this stove was a bit to big for my house but did not realize just how much of a heat beast this stove was going to be. My Jøtul was technically too big too, but nothing in comparison to this stove. I had never used a catalytic stove before and did not know just how much heat they create. I just keep a couple windows open a couple of inches when needed. When we get those below zero days, the Jøtul could not keep up but I am sure this one will and I will be glad I have the bigger stove.
I do have a question for those with this stove, as we approach spring, is it ok to leave the catalytic bypass opened and just have a small fire? The secondary burn would still work to keep it EPA compliant.
The other thing I have noticed is with the living room the same temps as I use to keep it with the Jøtul, the back rooms are about 3-4º warmer. That tells me this stove does distribute the heat more evenly...a good thing.
Overall, I am very happy with this new stove. I do think the weakest link is in the air control lever as it is very hard to adjust for consistency. I see on some of their new steel hybrid stoves, they have a more robust control with click style stops. I know it would take a complete redesign for this stove and they will probably never do that but something like that system would make minor adjustments easier. Having said that, the more I use the stove, I am starting to get more use to it and I am sure going forward won't be that big of an issue as it was at first.
