I hand file my chains with a husky roller guide and usually think I get get good results. I expect that the "boiling water" principle applies where my sharpening results slowly degrade from a new chain. This past weekend I was getting rid of some large trees that I had dropped the previous weekend. I went to cut the first round through a 16" diameter white birch and when I got to the end of the cut I saw the telltale sparks coming from the cut and found a small rock sitting directly under the trunk not visible in the duff. That chain was toast so I let the saw cool off and installed a new out of the box chain.
I started cutting and felt like a Jedi night, the birch and a couple of similar size maples all turned into rounds with little or no effort. I ran out of gas and refilled and kept going with similar results. Not much later I had all the trees brushed out keeping everything over 1.5 inches for rounds. I will probably touch the chain up a bit before the next run but expect the inevitable decline has begun.
The old chain could probably be recovered but I am going to have to file back a bunch of the hook as the teeth are ground down on the top from the rock. I guess its probably going to go in the dead chain collection and I will pick up a new one.
