M
MnDave
Guest
Fellow wood burners,
This is my first post here at Hearth.com. Seems like a great place to learn and share ideas.
This Quadra Fire 5700 is my 5th stove in 30 some years. It replaces a wonderful Kent Tile Fire. I loved that Kent and used it for 10 plus years, unfortunately it would not hold enough wood for an strong overnight burn here in Minnesota. I mean there were enough coals in the morning to get a fire going without using kindling but the house was down to 65 on a really cold one (again Minnesoooota). My wife will complain if she wakes up to a cold house and I like to keep her happy if ya know what I mean
. So when that furnace would start cycling at 4 AM it would bug me enough to get up and reload but I always wanted to fix that problem.
So, the main reason I bought the Quad 5700 was for the 3 vs 2 cubic foot firebox. I also liked the ACC starting system (so far so good).
Well after a few small burns to get the paint cured I decided to build a medium fire using 5 splits of red elm. Even with the burn rate control on the lowest setting the stovepipe temp went to 525 F. That is too high to my liking. I did have the feeling that the stove would probably not overfire with more wood at the low setting (kudos Quadrafire), but the fire was raging like I have never before seen. Definitely not my idea of efficient as this burned to the coal stage in less than 2 1/2 hours. I had trouble imagining how a full box would burn overnight. That kept me up that night as this stove needs to "walk on water" given it's pricetag.
Actually, I was not too surprised that the burn went almost nuclear. Before I installed it, I had the heat shield off to examine the air controls and make sure that I understood how they worked. I found that with the burn rate control set at the lowest setting it still had a decent opening so it cannot fully shut off the air to the top front of the box. Also, the secondary manifold has a fixed 3/4 inch round opening. I wondered how that was going to allow me to control the stove and I found out... not too good.
After reading a lot of great information on this forum, I now understand why this "EPA stove", made in Washington state, has this kind of air control. Specifically, the Florida Bungalow Syndrome article by John Gullard. It makes perfect sense. The EPA has to make these stoves to be fool-proof. Otherwise, the air pollution of a smoldering wood burning stove could be outlawed in the country someday like it is in the city today. But I am not a fool . I know that smoke means wasted energy and creosote. I don't burn like that.
My chimney is around 25 feet of effective height with an outside air kit so my draft is pretty good.
Anyway, I could see right away that I needed to get better control over the air flow rate to get the efficiency/burn time that I want. So I took the side shield off and made two simple modifications. One, I placed a piece of angle iron over half of the 3/4 inch hole in the secondary manifold. Two, I placed a piece of sheet metal on the main burn rate control which allows me to fully close the shutter assembly (although I do not intend to run that way).
I fired it up and for all intents and purposes it appears like I nailed it. If I close off that main burn control I can bring that blaze to it's knee's in less than a minute. With the burn rate control in the middle of the range I can control the stovepipe temp in the range of 350 to 400 F while the gasses are being burned. When the stove pipe is in this range the lower stove top is 400 to 450 F respectively.
The pipe temp does drop below 300 F in the coal stage but IMO since the gasses are mostly burned off I will not be creating a creosote problem. I use the chemicals and run the brush through mid-season just in case.
I sincerely appreciate the information here on this forum. If it was not for this information I would have been calling the dealer and I doubt that they would have done any modification and would have instead told me about how super clean the stove runs. Super clean is good but it seems that clean has not caught up to Minnesota yet. My one neighbor burns leaves for days and the smoke is so dense it drives me indoors if the wind is right.
I don't think that the burn times that these companies list in their brochures are "typical" except maybe for a bungalow in Florida on a 60 degree day.
After this winter I will post here on how much wood I burned and how I feel about this stove. So far I am liking what I am seeing. Thanks Quadra Fire.
Respectfully,
MnDave
![Wink ;) ;)](/talk/styles/default/xenforo/smileys/wink.gif)
Respectfully,
MnDave
