Score this is a tree that I looked at a couple months ago and needed a block and tackle because of the 30 degree lean well last night it fell across the road. Will post some pic's and cut it out Sunday A.M.
Hunderliggur said:Wind does a wonderful job of getting rid of various liability and safety issues. Unless, of course, you are just unlucky enough to be under the tree when it falls;-)
Rob H said:How long has that thing been dead? The tap root is GONE! If it has been dead for long the wood isn't worth much.
smokinjay said:I had the lawn and tree and shrub maintenance on this place for more than 10 years
ISeeDeadBTUs said:smokinjay said:I had the lawn and tree and shrub maintenance on this place for more than 10 years
So yer the guy that sprayed all those chemicals that killed it huh??
The wood will be excellent. I don't know about hickory, but standing dead oak generally doesn't rot. Once it tips over and is resting on the ground, then it will begin to rot, but even that could take a decade before it becomes too punk to burn.Rob H said:How long has that thing been dead? The tap root is GONE! If it has been dead for long the wood isn't worth much.
quads said:The wood will be excellent. I don't know about hickory, but standing dead oak generally doesn't rot. Once it tips over and is resting on the ground, then it will begin to rot, but even that could take a decade before it becomes too punk to burn.Rob H said:How long has that thing been dead? The tap root is GONE! If it has been dead for long the wood isn't worth much.
