- I just finished building and firing up my gasser, and trying to get things balanced out. I built a water jacketed down draft with heat exchange. Using the RU-2001U to control the process and Steibel Eltron 3 speed circulation pump. I am finding that I have to run the pump on low to maintain temperature once set point is reached other wise it cools the water and only pumps about 50 gallons before going into heat cycle again. I also initially had an issue with once it reached set point to start pumping, the water temp would over run and put the fire into stand-by mode, I think that was just an air pocket which I have since resolved by raising the water in the storage tank. I have the temp probe mounted near the top, have considered lowering it but unsure on that one.
Total set up is the gasser water jacket holds about 100 gallons, 500 gallon dairy storage tank to store hot water with about 400 gallons in the tank. I draw to the gasser from the bottom of the horizontal tank and discharge into the center of the tank.
Any thoughts or suggested appreciated.
Dogshark
