I am currently trying to decide between a Jotul F100 Nordic QT and the F3 CB. My house is around 750 square feet and is made of concrete block. There is insulation between the basement and the main house, and in the ceilings. However, the walls are just block with an interior stud wall and plaster finish with no insulation.
I am trying to figure out if I need to go to the bigger size, even though my square footage isn't that big, just to make up for the lack of insulation. I don't need the house to be 80 degrees, just to have the living room be comfortable.
I am leaning towards the F100 due to the fact that it is easier to move, less expensive, and more attractive in my opinion. Either way, the stove will be hearth mounted into a standard fire place and I plan to fabricate a steel back panel to block heat loss through the fireplace.
So, do you think the F100 will cut it?
Thanks for any advice you guys can give.
