Hello all I have been using a brand new Jotul Oslo and have it pretty well figured out. I was hoping someone can answer a few questions for me. I have been babying the stove and keep it running between 450-550 on stove top thermometer in front right and back left after backing the air control off to about 1/4 open. This has been giving me decent heat and burn times.
My daughter after being told not to mess with the stove decided to throw some wood in and just left the air control fully open and went to bed. I know she needs to know what to do, and I have already given her multiple tutorials and she basically just cannot follow instructions so please don't scold me about having people in the house who cannot operate the stove by the way she is 18 and just a new age child. I have no experience with EPA stoves just older stoves that would run away from you unless dampered down mainly due to air leaks. The stove was definitely not stuffed to the gills she probably threw in 2 20in 4x4 or 3x3chunks
Are these Jotul stoves designed to handle decent size hardwood splits with the air wide open? I am assuming there is no damage because the stove can be run with the front screen. I assume it is just wasted heat up the chimney. I did wake up this morning to a faint familiar smell the smell of a new high temp being reached, and when I seen the air control open I got a little worried. I haven't really tested the stove out as I always start to move the air control at about 275, or 300 then just increment it back to about 1/4 open and let it do what it should do and I get about 2-3 hours in the 450-550 range followed by 1 hour 400 1 hour 350 then about 2 hours of 200-150. So I don't know how the stove behaves with the air control wide open. Just looking for either reassurance, or someone to give me a good reason to have a child move out of the house haha.
