Hi al, I have a V3 Oslo installed March 2023. I run it pretty much 18 hours per day as its our only source of heat. Its going well so far. The stove is tight so far. I've actually had issue with losing draft since I installed the factory blower on it (doesn't matter if i'm running the blower or not, it used to draft better). I run it now with the air controller wide open most of the time.
I have a source of coal and I was thinking of supplementing a few pieces of coal in along with wood. Any reason why this would be an issue? I am guessing only issue would be over heating and maybe something where the Fusion combuster doesn't like the constituents in coal.
Speaking of over heating, how is that defined on this stove? The absolute hottest I get is 600 on the top plate (measured using a standard magnetic circular thermometer) and 1200 in the hole near the rear which measures temp after the combuster (using a probe thermometer that the dealer gave me). Usually I am running 500 on the top plate and 1000 on that rear thermometer.
