Here is a picture of my set up.
I was wondering if adding a rear hear shield would be of any benefit directing heat forward? Would there be any downside?
I've been running this set up for about 4 years and satisfied with the heat output. The stone and block work does suck up a lot of heat if I run continuous which is a good thing If I did burn 24/7, but I don't.
I mostly load up once when I get home from work then at most one reload if someone is staying up late or its really cold. I really just use the stove as supplement heat.
The stove sits mostly outside the fireplace. The whole chimney is interior and I'm guessing my liner is about 28 ft total from the top of stove. I do have a block off plate.
Thanks for looking.
![Jotul Oslo f500 V2 and rear heat shield Jotul Oslo f500 V2 and rear heat shield](https://www.hearth.com/talk/data/attachments/308/308945-a717632d1b862db5effa704cfe3d6d39.jpg)
Thanks for looking.
