Jotul GF600 DV ii
Pleasant1
8
MA
Stove was purchased used and was said to be running on propane. I had it installed in a barn loft. the following has occurred since:
lit by plumber after install, working but remote did work (ordered new remote)
next time stove was lit, was on, then huge poof explosion and went off (pilot also)
several days later, after installing new remote, lit stove, ran for 45 min, turned off
next time stove was lit, remote set, ran for approx 2 hours and went to set temp, then upon turning up temp, small delay of time, poof sound, went off, burner only, but would not start again either on thermostat or manually with the remote
next called a technician who investigated and decided it may need a new pilot assembly which was ordered and installed, stove seemed to be working
next time turned on with remote set to 64, worked for approx 2 hours, went off when temp reached 57, checked with remote mfg and they said was under warranty, will replace
next lighting with remote, but manual on, poof then stove completely yellow inside
Does anyone know how to proceed with this?
