I'm not sure if this is unique to the Firelight 12, or if the Firelight 600 shares the same design. I do know many of the castings from the 12 were re-used in the 600.
In any case, there's an adjustable plate / damper of sorts, across the top of the door. It seems to me it's designed to adjust the air wash across the door glass, but I'm not sure why the manufacturer made this adjustable, or how one would know if they have it opened (or closed) too far. It's held in with two bolts, one on either side above the door (stick your head in the stove front load doors and look up), and these bolt holes are slotted to allow adjustment if the bolts are loosened.
When I received this stove, those bolts were loose, and the damper was slid all the way forward/closed. Not knowing where to adjust this when I re-tightened the loose bolts last year, I figured a safe bet was to aim for the middle of the range.
My glass does get filthy, but I'm burning less than well-seasoned wood, and I'm forever burning on a very low setting. Perhaps an adjustment would help tailor the air wash to my burning style, but I really don't have a clue. I did try opening a bit farther last night, but haven't noticed any improvement in my glass (yet).
Any wisdom?
Any wisdom?
