Jotul guys: Anyone have the F600? How do you like your stove? Any problems/issues? Burning full-time or weekends? How many sq. ft and climate are you in? Thank you very much for your time everyone.
Thank you for your response. It looks like a great looking stove. I know the wife would approve. I like the side load door as well. Is there adirons to keep the logs from rolling on the glass?This is the end (hopefully soon) of our eighth season with our F600, heating 2100 sq.ft. We use it for at least 95% of our heat, and usually have three fires a day of varying sizes depending on outdoor temp. Furnace is likely to come on (set at 68*) in the morning hours if it's single digits or below outside.
I've had to replace the top baffle plates a coupla years back (120$ if I remember correctly) because they became warped and it looks like I will need to do it again for next season. Other than that, no problems.
The blue/black enamel is the way to go in my opinion.
I will do that. ThanksThere are several past threads on the F600 that you may find helpful. Try a search for more info.
How is that happening...running the stove hot, trying to keep up in cold weather? What stove top temps do you run?I've had to replace the top baffle plates a coupla years back (120$ if I remember correctly) because they became warped and it looks like I will need to do it again for next season
Would the baffle plates be covered under the Jotul warranty? I was reading thier warranty and the baffle has lifetime warranty. How is that happening that those plates keep warping? Any ideas?This is the end (hopefully soon) of our eighth season with our F600, heating 2100 sq.ft. We use it for at least 95% of our heat, and usually have three fires a day of varying sizes depending on outdoor temp. Furnace is likely to come on (set at 68*) in the morning hours if it's single digits or below outside.
Happy to hear you like your F600. Its a beautiful stove. I really like the side door on it just like my heatrthstone. I load almost all the time with the side door. I know Inwill miss that if I buy the F55 or PE T6. I am not sure about the burn tubes not being very robust as I will running the stove pretty much full time 5 months out of the year. Thanks for you info and to everyone else who responded.We're a happy F600 family. We have a two furnace house, so one is set back to 60, the other we turn on in the morning to help get up to "warm".
The rest of the time, it is the stove exclusively, unless we get a real cold snap. The F600 keeps our post and beam section (~1200 sf--with too much glass and too little insulation) comfy (67-68) through all but the coldest days. Some heat moves to the back section, but the furnace will cycle occasionally.
The cast iron plates/burn tube assembly is not very robust. So far I have replaced the plates once, and then the burn tube assembly, but the stove I started with had been overfired, so the problems may have started before I got my hands on it. Replacing the plates/blanket is trivial; the burn tube assembly requires pulling the top off the stove (If you look at threads I have started, I documented the burn tube swap...) I think the cast plates are just a little to light to do the job--we have not run our stove over 500. mostly this year it has been small and frequent loads with biobricks running around 300-350..
There is a thread here where someone replaced the cast plates with fire brick and stainless tubing--I thought it was a good idea too.
But the good outweighs these niggles--the side loading is a godsend (no ash spilling out the front door), the ash pan is nice, and best of all, it's a Jotul!
Keep in mind the f55 is designed to be loaded north south so I'm not sure you will miss a side loader. Also the baffle is a one piece stainless unit and from the looks of it I cant ever see it really failing.Happy to hear you like your F600. Its a beautiful stove. I really like the side door on it just like my heatrthstone. I load almost all the time with the side door. I know Inwill miss that if I buy the F55 or PE T6. I am not sure about the burn tubes not being very robust as I will running the stove pretty much full time 5 months out of the year. Thanks for you info and to everyone else who responded.
