I just found my old thread for rebuilding our stove in 2017, and it is in dire need of another rebuild. ![Down :( :(](/talk/styles/default/xenforo/smileys/downer.gif)
Baffles are warped (that is the second set I have installed), and the burn tubes are toasted (damage is not as bad as last time (2017) on the manifolds).
In the meantime prices are way up for parts--I managed to snag the whole burn tube assembly on eBay for $350--but the cast baffles are now running ~$70+ ea, so $140+ for the pair. Luckily I have an unused fiberglass blanket since the last time the old one was in good enough shape to reuse.
From our thermometer, I don't think we are over-firing, but we do have periods where the stove is going continuously for weeks on end. Other people here have complained about the baffles slowly warping under continuous burning--but it doesn't seem like that is true for everyone.
AFAIK, our stove is fairly tight--all new gaskets when I last rebuilt, checked for leaks last rebuild (and did some filling of top corners where stove cement was needed) doors are closing well, and the ashpan door does seem to close tightly (although I have probably had some occasions where the dreaded ash build up has meant it was not sealing as tight as it should.)
One user (Dexter) had the precursor stove, and did a modification where he used split fire brick sitting on 3/16" steel dowels running at right angles to the burn tubes as a substitute for the cast baffle plates, and with the stock insulating blanket on top. This meant no more baffles warping and seeming unchanged burn performance, so I'm seriously considering this as a solution.
Any thoughts about the modification?
(It could be that the train of events for failure is first the baffle plates warp, and then the burn tubes get fried when the flames are not channeled towards the front of the stove for a proper secondary burn?)
[Dexter's comment can be seen here: https://www.hearth.com/talk/threads/firelight-firebrick.19207/#post-289151 ]
