If you pull the trigger on that buy, make sure to post your result. I've been running an F600 for four years now and am thinking about moving to the F55 next year. I like the look of the F600 better but every other year I have a maintenance regime for it that costs me about $350. I think the welded steel construction of the F55 would eliminate most of my maintenance costs.
I also heat exclusively with an F600 and have almost zero maintenance concerns.By the end of every other season I notice that my burn times are somewhat shorter and that my reloads are taking off faster. So during the summer I buy all new gaskets, door glass, and ceramic insulation blanket for above the baffle and and clean the entire stove and install all my new parts. During this process, I also use refractory cement to seal both bottom rear corners. I've noticed that while cleaning, some ultra fine ash will leak out of those corners. Not enough to measure, but just enough to see it if your'e familiar with the stove. I've talked to Jotul about the ash and they claim that that shouldn't happen, that the stove should be airtight at all times. I figure its because the stove is cold and has opened a joint down on the bottom corners. When its hot everything is sealed up and there's no ash. Anyway, the bulk of my maintenance cost is the glass. I don't need to replace it but the fire looks so awesome through new glass!
This is definitely excessive and it sounds like unnecessary maintenance. The gaskets usually are good for at least 5 yrs. If you get an F55 you will have the same costs if replacing the glass annually. How are you cleaning the glass? After a year is your stove glass excessively fogged? It shouldn't be. When I sold our Castine after 2 seasons the glass still cleaned up very clear.When its hot everything is sealed up and there's no ash. Anyway, the bulk of my maintenance cost is the glass. I don't need to replace it but the fire looks so awesome through new glass!
I would also price a new F55. Call around to several dealers. These stoves are being discontinued after this season so some dealers and distributors are going to be selling the new F55s at deep discounts. Why not buy a brand new one with a full factory warranty? Just a thought.Looking at a used jotul f55 with a blower for $1500 2 years old any advice would be greatly appreciated Thanks
My house is 1800 sq ft built 1940 in Massachusetts Cape style
A couple things to check are ash buildup behind the ashpan. If too much builds up there it can prevent the ashpan door from closing tightly. And when the stove is really clean, wipe down the grate area with a damp rag and look for any cracking in the stove base surrounding the grate.
What I meant by that is the current version will be discontinued. I don’t know if they will put a cat in a new version or try a different baffle design like Pacific Energy. The stove you see today does not meet EPA2020. Make some calls and find out for yourself. This is what I have been told by dealers in my area. I hope they keep the f55 but I honestly do not know. Be sure to thank the folks at the EPA for this.Thanks begreen. I thought it was a great stove and folks here had good experiences - was surprised to see someone here mention it was being discontinued.
The new EPA approved stoves get even more heat out of the wood than the stoves previously available. How is that a bad thing?What I meant by that is the current version will be discontinued. I don’t know if they will put a cat in a new version or try a different baffle design like Pacific Energy. The stove you see today does not meet EPA2020. Make some calls and find out for yourself. This is what I have been told by dealers in my area. I hope they keep the f55 but I honestly do not know. Be sure to thank the folks at the EPA for this.
