It's kiln dried wood but I didn't make the air shutter "all the way left" once added, because I worried the creosote built if close air shutter soonHow long do you wait before turning it down? I have found with good wood I need to be aggressive in cutting air or it gets away from me.
Yes center of top.500 stove top temp? It’ll take some trial and error learning a new stove. I prefer to watch the flue temps when dialing in a burn they react faster than stove top temps.
If you have good dry wood I would look into a flue thermometer, you may find it gets plenty hot quick and you can turn down in stages without creosote. Stove top is always slow to catch up.It's kiln dried wood but I didn't make the air shutter "all the way left" once added, because I worried the creosote built if close air shutter soon
Understood, thank you.If you have good dry wood I would look into a flue thermometer, you may find it gets plenty hot quick and you can turn down in stages without creosote. Stove top is always slow to catch up.
Reading……Questions about starting a fire and avoiding a runaway stove come up so frequently I decided to document starting our stove. This is a Pacific Energy Alderlea T6 with about a 3 cu ft firebox. The stove is connected to a straight-up, 20' interior flue. The outside ambient temperature is 34ºF. The blower was off all the time for these shots. The firewood is douglas fir at about 17% moisture content. This is a N/S loading. An E/W loading start will follow.
NOTE: as testing will show, the older Condar flue thermometer is reading low. It needs recalibration.
There are 3 instruments shown.
- begreen
- Forum: The Hearth Room - Wood Stoves and Fireplaces
Great tips in this thread!
It looks pretty normal. Closing the air sooner will tame it a bit. If the wood is dry, creosote concerns will be less unless the flue system presents too much cooling. A flue thermometer will help in guidance, with a digital probe being the best option.It's kiln dried wood but I didn't make the air shutter "all the way left" once added, because I worried the creosote built if close air shutter soon
Received.It looks pretty normal. Closing the air sooner will tame it a bit. If the wood is dry, creosote concerns will be less unless the flue system presents too much cooling. A flue thermometer will help in guidance, with a digital probe being the best option.
As shown in the picture: the chimney runs inside a chase enclosure, with approximately 27 feet of ICC-Excel chimney pipe. The wood stove’s double-wall black pipe first rises vertically for about 4 feet, then goes into the wall and connects to the chimney, which runs vertically inside the chase.There will be smoke in any stove until the firebox, and/or cat, gets up to temperature. There will definitely be some soot and ash buildup over time. That's non volatile and quite different from creosote buildup.
The flue system design can affect creosote buildup. Describe the flue system on the stove. Is it interior, straight-up, and through the roof? Or does it connect to an exterior (brick or metal) chimney? How tall is it in total?
By the way, I have one more question: this brand new stove was installed last week, and I live in Orange County, New York. Next week, the daytime average temperature will rise to 50°F, so I might only burn occasionally in the mornings and evenings. In that case, do I still need to do a chimney cleaning this year, or can I wait until next spring?Stove top thermometers aren't all that helpful. The mass of the stove body can take a while to heat up. What is important is the combustion temperatuere in the firebox which you can't easily read. It has to be above 1000º for secondary combustion to take place. For this reason, I rarely look at the stove top temperature, it's often too far behind what is happening with the fire - a lagging indicator. The best option for knowing how the fire is burning is visual and by the flue gas temperature. Visually, your fires look great. The second fire is hotter as indicated by the clearer, blue flames.
Thank you so much for your advice! I’ll keep it in mind!It will likely be ok to wait but this will depend entirely on the wood burned next fall/winter. A load of poorly seasoned wood can gum up a chimney in a couple of weeks' burning. It's a good idea to clean after each cord burned while getting familiar with a new stove and wood supply.
