I hope a Jotul F500 V3 owner can verify this for me. Are the baffle system and tubes easily removable in the new Oslo? I'm trying to verify if using a soot eater through the stove and a 90* tee just outside the rear flu vent is viable.
Does it still. On the v3?the top of the f500 comes off fairly easily - i'd imaging you could gain all the pipe access you need that way
I'm sure some folks who have this model or have cleaned one can clarify if that is necessary though
Isn't the large cat in front of the flue exit on the V3? There is no bypass.
hopefully someone with one in their house chimes in to keep me honest but when i was looking at the f500 my dealer actually displayed one with the top off. I don't remember it in great detail but i do recall thinking it wouldn't take more than a few minutes to open her up and access basically anything I needed. I want to say either the cat was forward enough that I didn't see an issue, or that it would come out so easily that I didn't mind.Isn't the large cat in front of the flue exit on the V3? There is no bypass.
That’s a very nice stove!I haven't tried yet, but probably will soon, but removing the top maybe a challenge because of the limited clearance of my particular install.
The baffle appears to have 6 screws holding it up. Does anyone know if I remove them, will I be able to gain access to the flue pipe for cleaning?
View attachment 284218 View attachment 284219 View attachment 284220
I would be taking the top off to get it all back in. The fact that those screws aren’t on the parts diagram and the baffle is an assembly I’m not surprised that what you found out.If you have a Jotul F500 V3, DON'T remove those screws. Removing them only separates the two parts of the secondary air chamber and doesn't give you access to the chimney. Its a real PITA to get back together plus there's a rope gasket that I'm going to need to get a replacement for and glue back in now. UGH.
If you pulled it out the the front of the hearth and put down appropriate floor protection can you get the top off easily?In hindsight, picking the biggest stove that would fit in the opening turn out to be a bad idea.
Your stove needs ember protection only as long as it isn't in an alcove.I'll measure tonight but i think the stove would need to sit almost at the front edge of the hearth to have room to remove the top. The floor in front of the Hearth is ceramic tile over plywood. Would additional protection be needed if I pull the stove all the way forward ?
How much will switching from a vertical exit to a horizontal with a 90 effect the draft? There's allread a section of flex connector pipe bent in a S shape to get from the stove location to the chimney flue. I know the installer preferred the vertical exit for better drafting. The current setup has plenty of draft.
Yes there is a stainless liner run to the top of the chimney. My fireplace chimney services two stacked fireplaces. Each has it own flue, one offset to the right the other offset to the left.Your stove needs ember protection only as long as it isn't in an alcove.
When you say it has a flex connector in an s shape to get to the flue it concerns me a bit. Is there a stainless liner from the stove running through the chimney to the top?
Ok just checkingYes there is a stainless liner run to the top of the chimney. My fireplace chimney services two stacked fireplaces. Each has it own flue, one offset to the right the other offset to the left.
No problem. Any thoughts on if I add another near 90 degree bend would it still draft adequately? The chimney is approximately 25' tall.Ok just checking
At 25' tall it shouldn't be a problemNo problem. Any thoughts on if I add another near 90 degree bend would it still draft adequately? The chimney is approximately 25' tall.
