I moved into a house with a Jotul F500 V1 Oslo stove in June 2020. It was original to the house and started service around 2003. We have been burning wood (about 3 cords/yr) "fine" with annual chimney sweeps. All the stove behavior was expected and I was able to use it without issue. This year I decided to replace the air chamber, baffle, blanket, cracked side panel, and new/worn gaskets from upgrades. Getting into the season the stove has not been burning well at all. I have narrowed it down to starving for air. At one point experienced severe backpuffing. Interesting to watch. I first thought it was a back pressure issue. I have opened windows with no luck. You can tell the fire is banking and when I open the side door I get rolling smoke unless the fire is ripping. Even then seems unstable.
Before I have the chimney tech to come out again to see if there is some blockage, odd since it just was cleaned before season I would like to rule out other things. One item comes to mind is the previous baffle was so warped and split it did not do much. Maybe the other older gaskets were making up for the lack of intake airflow.
Wood I am burning is well seasoned and very dry.
Video of "hot burn" - https://photos.app.goo.gl/DGLNKqodiziwV5569
Any personal experience or ideas?
Thanks!
Thanks!
