New to the forum, and new to wood stoves in general. Here comes my really long first post, bear with me.
Recently acquired a new (to me) Jotul F400. Just finished installation, brand new chimney. Finally got everything buttoned up and went to fire it up for the first time last night. A lot of smoke started to come from the bottom of the stove, specifically the round hole right behind the ash pan. Had a buddy over that has a lot more experience with wood stoves and he was surprised at the amount of smoke.
From what I can figure a couple things were probably working against us and all signs point to a draft problem. Wasn't all that cold out, around 50 degrees F. House is fairly new construction and is sealed very tight, probably couldn't hurt to crack a window next time. It is configured for a rear exit, which could exacerbate the above conditions.
That being said, since the stove is used (2 seasons, talked to them and they never had problems) is there anything I should look for? From what I can tell everything is installed correctly, the air control operates, chimney is a straight run up the side of the house (confirmed wide open), no dampers. Could something in the stove have been dislodged buy moving it?
Thanks!
Install looks very similar to this: (stole the picture from this thread: https://www.hearth.com/talk/threads/castine-install-loads-of-pictures.45247/)
Thanks!
