Considering this for my house, 1200-1500 sq ft new (<10 y.o.) ranch. Any feedback regarding performance, size or other would be great before I pull the trigger. FWIW, we have an oil furnace to back it up, but would like to decrease the use of dino fuel as much as possible. Also, we like it on the cool side, like 58*F.
For a newer and hopefully well insulated home I would also look at a catalytic stove like the BlazeKing 20 series or the Woodstock Fireview. You will get a more controlled heat output and longer burn times compared with a secondary burn stove like the F400 or the PE T5. Consider adding an outside air kit should your home be relatively air-tight.
