Hello All,
Brand new to the forum, not new to woodburning. Recently upgraded my Quadrafire voyager insert to a Jotul F400 to get away from the blower and enable longer burns/easier ash removal. The F400 is a used stove I bought for $1K that I believe is in good shape. Stove is rear exit setup into a SS liner all the way up a 2 story exterior masonry chimney.
I am struggling to control the stove with these symptoms:
I struggle to get the stove going at startup unless opening the ashpan door
Once the stove is going it is sluggish to gain temp up to 350F
I start to gradually close air as the stove warms and at the point I get steady secondaries I typically move the air all the way left (closed); still hear roaring of air into the firebox
When I have a full load in, this sometimes "runs away" and I get 600F+ on the side of the top plate and 750F+ in the center of top plate at which point I use alum foil to cover the intake. Then I get a BEAUTIFUL SLOW SECONDARY FLAME.
Is this (600F+ on the side & 750+ center) a concern or operating as intended? I know the air control works because when the draft isnt so strong, shifting left will smother the fire quickly.
Thanks for the help.
