Good afternoon! I've burnt wood for about 15 years in a garage at another house,
and with an Old Mill and stainless chimney I never had any problems. The chimney
was always clean, with stack temps at 300 F or better.
I've moved into a new (to me!) house, which has a Jotul F400 single door stove. I've
cracked the code on how to get a fire going quickly, and can usually get the stove
up to temp within 30 mins or so. My record is 18 minutes from a cold stove to a 300 F stack
temp and a 400 F stove top temp.
When I start the stove, I ususally run the stack temp up to about 350F (magnetic thermometer
on single walled pipe), and get the stove top to about 600F-650F, and then back the air
down. At this point there are no visible emissions. The stove cruises around 600F with about a 300F stack temp. Chimney is about 20 - 24 feet of masonry with a stainless liner. I cannot get the stack temp over about 350 F without beginning to approach 700F on the stove top. Is my stack temp hi enough
for long enough with this setup? It runs for an hour or two at 300F before it begins to drop off
and the fire urns down to just coals. I see just light fluffy balck stuff in the chimney.
Thanks for your opinions.
-Stretch
-Stretch
