Well I ended up getting rid of my Jotul 118 1970`s stove and purchased a Jotul f400 on CL for $350. Its probably a 2008 model it has the double doors. The guy told me that th secondary burn would not work so he was selling it to get a newer stove. I took it apart and put in new gaskets and now the secondary works great. I lit a fire for the first time this morning and its cranking away. The outside temp is about 42~45 but it seems to het great with little smoke outside. So far the only issue was getting it to start. It seems like the only good way to start it is to open the ash door which is not adviseable. Im thinking I need to add a little more stove pipe to create a better draft. My chimney is real short like 12 feet max from the top of the stove. It goes through a single story ceiling on the front of the house. Once the fire was going new wood catches fast. The stove was actually running at 600 with the air closed down to 25%. If anyone has experience with this stove does it sound like I need more chimney and is the fire only hard to start because the outside temp is still not real cold yet?
