Jotul C450 insulated blower cord wrap? Temp at blower motor?
black_sab
64
massachusetts
Looks like my "new to me" Jotul is missing the power wiring for the blower, and the blower cages are REALLY tough to spin.
Anyone out there have a recommendation for some high temp power cord wrap or tubing so that I can make my own cabling?
This stuff here says 500F continuous...
http://www.amazon.com/Black-Heat-Sh...1425116&sr=8-1&keywords=high+temp+wire+sleeve
Is it safe to assume the max temp outside/near the case is going to be < 500F?
You should be ok with that encasing you power cord. it gets hot down there, but not THAT hot.
Reactions: black_sab
It's possible that the motor bearings are almost frozen, probably due to lack of lubrication. The blower cage should spin freely. Lubricating the motor may take disassembly or drilling in new oil ports if there are none. If that is not possible then the motor will need to be replaced.
