I've finally built a roof platform, removed the crown and front damper plate with an angle grinder, and hauled out the 5 inch liner so I can measure the chimney dimensions. Here is a high level summary of chimney dimensions with additional detail and photos included below to help clarify.
Summary:
chimney height (fireplace floor to top of chimney): 15' 9"
upper chimney outer dimensions: 18x22.5"
upper chimney inner dimensions: 10x15.5"
lower chimney smoke shelf bottleneck: 6.5x15.5" (estimated)
smoke shelf height (from fireplace floor): 5'4"
After reading through more posts, I'm inclined to go with a Duravent rigid round pre-insulated 6" solution for the upper portion of the chimney, and either: (a) a short uninsulated flexible 6 inch; or (b) a short blanket/mesh insulated flexible oval 6" compatible (4.5"x7.4") to work around the smoke shelf. The smooth inner wall of the rigid sections is very appealing to me for regular cleaning and I like the idea of modular sections for a solo installation.
If I could remove the smoke ledge or a portion of the opposing bricks (5' 4" up) I could go with 6" pre-insulated round all the way up, but it seems like a fair amount of work and risk.
Another option to improve draft would be to extend the rigid round sections above the height of the chimney. I believe I read this in a post here, but I'm unsure of what kind of extension is advisable.
I wanted to update the post here before going ahead with it now that I'm able to get better measurements.
Details:
For the main upper portion of the chimney, the inner dimensions are roughly 10x15.5" all the way down to the smoke shelf.
Minor dimensions shown below:
![Jotul C350 with a 5" liner Jotul C350 with a 5" liner](https://www.hearth.com/talk/data/attachments/265/265093-509b02eb35b7fbe48f5a7fb25452556d.jpg)
The view from the top of the chimney to the fireplace floor is relatively unobstructed until the smoke shelf. The height from the top brick surface to the fireplace floor is 15' 9".
![Jotul C350 with a 5" liner Jotul C350 with a 5" liner](https://www.hearth.com/talk/data/attachments/265/265095-e137396c7453389e78b50ff39a552a09.jpg)
In the photo below you can just see the edges of a paper plate on the fireplace floor between the smoke shelf (lower portion of photo) and a thin cast iron piece remaining from the damper assembly in the back of the fireplace that is proping up some fire bricks. A portion of the masonry that was chiseled out just above the in the first installation can be seen in the same photo.
![Jotul C350 with a 5" liner Jotul C350 with a 5" liner](https://www.hearth.com/talk/data/attachments/265/265097-e825c70198f8343f763f0537740b2bb6.jpg)
Below is a look up the chimney from the fireplace at the same bottleneck after I removed the front damper plate with an angle grinder. This view shows the bricks that were chiseled out from the initial installation, the same thin cast iron bar from the above photo supporting a few fire bricks, and the lower surface of what I believe is a smoke shelf looking up the chimney.
![Jotul C350 with a 5" liner Jotul C350 with a 5" liner](https://www.hearth.com/talk/data/attachments/265/265096-26b3c6182d3e154b36743087896bd9a7.jpg)
The height of edge of the innermost portion of the smoke shelf (red dot from range finder in photo below) is 5' 4" above the fireplace floor.
![Jotul C350 with a 5" liner Jotul C350 with a 5" liner](https://www.hearth.com/talk/data/attachments/265/265099-b5141efa013d17e8d26b672af3b9d1fc.jpg)
A height of 5 feet 4 inches matches the top bricks of the mantle in the fireplace.
![Jotul C350 with a 5" liner Jotul C350 with a 5" liner](https://www.hearth.com/talk/data/attachments/265/265111-5c0cb3392912117932339bfa6ac352b0.jpg)
I used a small plastic canoe paddle with a minimum width of 6" and maximum width of 6-5/8" to test the bottleneck. The 6 inch portion seems to pass through fine, but the 6-5/8" is just barely too wide to fit through straight.
![Jotul C350 with a 5" liner Jotul C350 with a 5" liner](https://www.hearth.com/talk/data/attachments/265/265119-d80de24504124c2aa0bfcce9c4a1bd21.jpg)
![Jotul C350 with a 5" liner Jotul C350 with a 5" liner](https://www.hearth.com/talk/data/attachments/265/265118-ad3b8fe3093bd957ee908841562761d6.jpg)
The 6-5/8" section of the paddle catches on the narrow dimension of the chimney at the location of the smoke shelf, but there is plenty of room in the other dimension.
![Jotul C350 with a 5" liner Jotul C350 with a 5" liner](https://www.hearth.com/talk/data/attachments/265/265122-befc9dbb2e34952b0a94627312195f66.jpg)
Summary:
Details:
