New member here. Lot's of good info in here but I have not run across anything similar to what I am experiencing.
Bought a cottage 5 years ago with a Jotul 8 with the spin draft in the front below the door. We use the stove a few times a year in the spring and fall. At start-up it leaks smoke around the top at the corners. This past weekend I pulled off the top, cleaned the entire stove removing all the internal plates, put a new 3/8" gasket in the top and door and replaced the glass gasket. When I went to put the top back on I noticed that the rim of the stove body is actually a bit larger than the opening on the top so the top gasket will not seal down onto the rim. It is hitting metal to metal. It does not appear that the exterior body parts have opened up at the joints as everything seems to be sealed. Maybe something warped from someone overheating the stove at some point?
Main Question: In your opinion could I take a grinder to the top enlarging the gasket channel and then putting in a larger gasket? I believe I could get the rim to seal to the top gasket by doing this.
Question 2: The back burn plate has a major crack in it. What are the cons of not replacing it. It seems to be readily available and if I can fix the top it seems like I should replace it.
Question 3: The door closes really difficultly. It did this before and after the gasket replacement. Any ideas?
Thanks for any input.
