Angus said:The 602 is ideal, I dont understand others saying to you that it wont burn for long periods, mine burns 24/7 and the lack of ashpan is easy, I have a steel bucket and a small shovel and it only ever needs emptied after about 8 or 9 days of continual use, it makes a lot less ash than other stoves !
As for the log size, 40cm is a long log and logs should always be split narrow so as to dry out correctly and not tar up your chimney.
It is a stove that can be slowed right down, without creosoting the glass or can be burnt quite rapidly to heat you up quick.
Go for the 602 its the largest selling stove worldwide and for good reasons !! Ive been using the 602 for 27 years !!
Angus said:Hello Gooserider, yeah, your right to point this out, I think there maybe some differant terminology in the States that i m not used to.
Both the 602 and the 118 I would class by you definitions as 24/7 due to Reload time and not Heating time. Generally the stoves will be left for about 8-10 hours and thats when the ash is raked, the stick goes on and it relights, without any kindling or manipulation, this happens virtually everytime, thats why I call it a 24/7 stove, which maybe wrong, but its one of the few stoves I have seen that will reload the next day without trouble.
Thanks for the explanation
Angus
Angus said:It heats a room of 85 sq metres, not sure what that is in feet.
Thanks. We weren't very aggressive on the temps or the wood volume, so the burn time was fairly short. I'm guessing we got about 3 hours before the stove temp really dropped. I was up quite a few times during the night, but I didn't check my watch.BeGreen said:Looking good PJ. How were your burn times between loadings?
That's what we aimed for but the air intake is in the door and the bottom of the fire box is only maybe an inch below the door opening. So you have to be really careful or coals just fall out the front of the stove. It's a 'lil bugger.BeGreen said:Have a small coal rake handy. When reloading, rake the coal forward toward the air intake.
