Right now I am frustrated and I need the help of this board..
Within three weeks I will be having installed a new Jotul 500 stove and I admit to being concerned in the wrong direction.
I will be mounting it on a 5ft by 5ft hearth pad so that is not the problem My problem is above the stove.
I will be venting it into the fireplace and it will be immediately in front of the fireplace box. My problem is, the mantel will not be the 16 inches minimum above the top of the Jotul 500. Even if I went with a smaller stove only the 602 would fit in terms of air space clearance to the mantel.
So, I accept the fact that the mantel has to go, but above it on the wall is wood paneling and behind that is standard wallboard.
So, can I keep the wood paneling which starts at about 14 inches above the top of the stove, or do I need to remove it and have a better insulated wall section?
If I need to remove and insulate the wall above, what would be the best way to do this, other then brick up that entire section of the wall?
I am thinking some concrete backer board as used behind stoves and in bathrooms, placed above the stove should do the job but I am not sure.
Thank you very much
David
Thank you very much
David
