Jotul 3 CB - Installing cast iron lid after conversion to back vent
cernick
2
colorado
I have a Jotul 3 CB that I just had installed on my fireplace mantel that used to be top venting in its old location and is now obviously back venting into my chimney. I have the the cast iron lid, traverse bar, gasket, and screw and am wondering the best way to seal nice and tight.
It seems as if the traverse bar sits in a grove of the stove hole opening, which then forces me to put the lid on and hand tighten the screw with my fingers since the baffle makes getting a wrench in there tough.
Am I missing something simple here or is there a better way?
Doing it the way I described it seems as if I was getting some smoke leaking around the seal.
Thanks for the help/advice.
Paul.
The whole top of the stove is just held in place by two small Allen screws. One on each side of the stove right under the lip of the top plate. Take the screws out, lift the to top off, install the flue cover in the top and put the top back on and tighten the Allen screws back down.
That did it! Thanks a ton. Much easier than trying to ram my hand between the baffle and the stove top while holding a wrench. :)
Thanks again!
Paul.
