It's Splittin' Time!
Bacffin
I still have 4 logs to buck up but I wanted to get this ash split as soon as possible. I know people burn this stuff green, so I threw a fresh split log in just for kicks. It burned okay but it still had that yuky wet smell when you opened the stove door. I'll face stack this load between the trees and see how it is in January or February.
~Bruce
  • It's Splittin' Time!
those are some nice rounds...the bucket must make it so easy for moving stuff around
i have had great luck burning ash a month or two after cutting and splitting off the stump. i have a similiar plan for some cold weather burning!
Reactions: Bacffin
Nice load of wood.
~Bruce
Better yet, January or February, 2014 or 2015. And I do not like to stack wood between trees. It is not good for the trees and if windy those trees move. Not good for the wood stack then. Much better to crib the ends.
Nice wood processing area & equipment.
Green wood burning "OK" ? Maybe it burned, but I'm skeptical with the "OK" part :)
Nice bucket full of rounds & piles of splits, you've been busy ;)
Reactions: PapaDave
not trying to derail the thread but... its only on one end and the tree is history when i build my new garage next summer.
Reactions: Backwoods Savage
That ash is probably sitting at around 30% moisture or more, wait till this time next year to burn. Just saying
The tractor was the best yard tool I ever bought ;)
How many cords will you have when done Basiffin ?
Some where between 6&8 is my quess. After it is split and stacked, I'll know for sure.
I agree, a couple of years would be much better for sure. Curious, how is it not good for the trees? I usually stack between decent size trees to prevent the stack from falling down. I didn't lose one log off a stack during superstorm Sandy's 60 - 80 mph gusts. I was suprised.
I should probably explain this one a little better, my bad. It is from log id 13 here https://www.hearth.com/talk/threads/log-id-lucky-number-13-please.91714/#post-1201382
It had no bark and was right around 20 on the moister meter on a fresh split. That's what I meant about burning just OK.
I already had the tractor and my kids knew I would be asking them to spend their weekends cutting a splitting my wood. That is why they bought me the log splitter. ;) Smart move on their part.
I agree with Dennis most of the time . . . but I've stacked between trees before with no ill effects . . . it really depends on the size of the trees (larger is better), tree species (thick barked species are better), weather/wind conditions and how you stack the wood. In the year or so I had a couple stacks between trees both the trees and stacks were fine and no worse for wear.
The bark of a tree is like the skin on your arm. It is there to protect the tree so why do anything to take a chance on harming the tree? I like to look at it the same as I would a vegetable growing in a field or garden. Put something against it and you cause damage to the plant or fruit. Also, if the trees are small then for sure wind will make them bend a lot and this will cause rubbing which will damage the tree in very short order.
I like the work set up, the small tractor and splitter. It looks like it works great in combination.
Looks like you are doing great! Money in the bank lol
