Unless you live in the Keys, think about it!I'm still burning both stoves as well. Not unusual, really.....
Took it for a spin, but returned soon after. After I went and got something to eat.Dexter snapped a pic the othe day when you were over there.![]()
I'm actually kind of glad we've had some cooler temps. as now I get to experiment with my new stove before the heating season this fall.
If I lived in the Keys, I highly doubt I would have a pellet stove....Unless you live in the Keys, think about it!![]()
I'm trying to decide if I'll go with the Stove temp setting or the Room temp when it gets really cold. I never had to make decisions like this with my old Lopi. The more I experiment the more I think I'll use the Stove temp with the manual setting (to save on the igniter).
Been runnin mine on stove temp the last few nights. Running it on 2 and is still a little to warm. Will probably work well when temps get below 20. Had it up on 4 to start and everyone started shedding clothes.
I'm sure many do....but how many who are in the Keys have pellet stoves??Ya know having a summer place on the island in the little pond across the street a bit from me fits in nicely with having a winter place in Florida. Plenty of folks do just that.
4? Are you talking heat setting or feed rate? It's gotta be really cold before I turn up the stove to 4.
The weather is changing nicely for us here. It's supposed to be around 75 degrees in a couple of days and there will be a few cool nights. We've got six bags left and and unopened ton. Saved a few bucks this winter. Now it's garden and back yard time.After one of the warmest winters in recorded history (up here in the Northeast), the last thing I would've ever expected, would be burning on May 1st............![]()
If I put my P61 in stove mode and flip the switch to manual, the distribution fan shuts down. You don't have to worry about the igniter in stove mode because the stove will run forever at the temp you set.
Really? The few times I've run my stove in "Stove Mode" it shuts right down once the probe senses the heat in the room has reached the desired temperature. And then it fires up again when needed, with the use of the igniter. My owners manual states that this is how it's supposed to work and putting the stove in manual does essentially the same thing except that the burn continues and reignites when needed from the low flame still in the burn pot rather than the igniter. I'm wondering if I should move my probe to a location further from the stove. When it was installed, the dealer mounted it right on the hearth behind the stove and I wondered immediately if it wasn't too close and would thereby shut the stove off relatively soon since it gets very warm in that location fairly quickly. But then again, I've only used it in the past few weeks with relatively warm temps. outside. When we get 5-10 degree weather in January, it'll need to work harder obviously. Probably best to wait and see before I dick around with moving the probe.
Everything you've stated is consistent with running the stove in Room Temp mode. When the stove is in stove temp mode, the probe is not in use. The heat setting, not room temp, is monitored by the ESP probe. The stove will run at that temp until you change it.
