Purchased a Jotul Rockland C550 last year to reduce our use of oil. Fireplace room has 2 entrances on opposite wall with an imperial room to room fan mounted in each entrance corner (see attached picture) The fan is facing outward to try blow hot air into the adjacent living room. While the fireplace room gets warm, not super hot, the adjacent family room does not get much warmer even with both fans running. I have also tried an oscillating fan on a high shelf pointed away from the fireplace room, to no avail. I tried facing an oscillating fan on the floor just outside the fireplace room, facing the fireplace room which does not seem to have made any difference. I have also hung a sheet around the staircase entrance so the hot air is directed into the adjacent family room and not wasted up the staircase to no avail (see attached picture for 1st floor layout)
Fireplace room does not have a ceiling fan at this time, but may possibly in the future. While I realize the insert is meant to supplement normal HVAC heating (oil in my case), the goal when this was purchased was to reduce our dependency an oil. I'm starting to wonder if its any cheaper to run the fireplace blowers plus 3 fans for a negliable increase in temperature for hours at a time vs traditional oil furnace that heats the house from 60-70 in 1 hour
Is there anything I can do to get the warm air spread into adjacent rooms?
