Start with shutting the damper before the the fire enters the home?!Now I'm curious to what that may be.
You have the floor!
This is simply a matter of making sure all seals are tight...if so then the draft must be an issue. Stoves can go wrong...no doubt, but there are only so many areas that can fail. Are logical air seals tight? is there a welding failure? is the draft correct?
