Thanks. It’s just that all the weight is resting on those 4 screws, as none of the metal of the legs touches the pad. So no leveling - they are carrying it all. And good eye on distances! It is 8” from the back of the metal to the wall and on page 13 of the Operating and Installation Instructions it notes 7.5” with a double wall connector. Should I put a heat shield on the wall anyway?The feet are fine that’s what the leveling screws are for. Just verify you have the proper rear clearance. 9” for single wall 7.5 for double. It looks close but I can’t tell how close
The previous chimney was used and the new stove plus connections were not quite high enough. I wondered whether I should see about having a new, higher pad installed. Or flat stones added underneath the feet. The hearth is level, as is the stove. But the weight is not distributed over a wider area, it’s concentrated on those screws and the piece of pad beneath themYeah that doesn’t look right to me. Those screws look too high almost like they were trying to elevate the stove for some reason? Is your hearth level?
That makes sense, thanks. I don’t want to take a chance but yes, we make the clearance by .5”!My understanding is that they are for mobile home installs that require the stove to be bolted down and leveling if required. If the hearth is level, then I would not use them. This is our T6, it looks better IMO without them.
There already is a heatshield on the back of the stove and no need for a wall shield if the clearance is honored or exceeded.
”She” said she needed them! Grammy as in Grandma, lol!I think he said he needed them since his connections were not high enough.
I assume it’s a rear exit. But doesn’t appear it’s an option. Definitely a slip should have been used.telescopic pipe you can adjust length.
I’m new to this terminology……do you mean that there is an alternative to the pipe which connects to the flue - that using one would allow the stove feet to sit on the pad? Thankstelescopic pipe you can adjust length.
Thanks but I’m new to the terminology y’all use. What is a ‘rear exit’ and what is a ’slip’, please! ThanksI assume it’s a rear exit. But doesn’t appear it’s an option. Definitely a slip should have been used.
thanks! I need to get in touch with the dealer and get this taken care of asap!If the pipe comes off the stove vertically, then a piece of pipe that slips inside another piece should be used. It’s called a slip or telescoping piece if you will. This allows infinite vertical reach. The pipe can be adjusted to the stove rather than using the levelers. That’s not what they are intended to be used for, they are just to allow for an uneven hearth.
Sorry! 😔That makes sense, thanks. I don’t want to take a chance but yes, we make the clearance by .5”!
Will do! ThanksIt's a top-vented stove. webby3650's suggestion is the best option. We have an adjustable (telescoping) stove pipe that makes fitting the stovepipe easy. Sometimes this just takes replacing the lower section of the stovepipe.
Can you post a picture of the whole stove pipe?
