Just got a Osburn Stratford II ZC fireplace and did my first burn today. For the first burn I loaded it maybe half way and once it was down to coals I loaded it "full" E-W to see how many coals I would have left in the morning. After it got going I closed the air control completely closed. Maybe this was a mistake, but I used dry 2x4s (all full 16" or so lengths, no thin cut strips). After a while it really got going and after noticing a faint glow from the secondary tubes and the air deflector I started to get really concerned I was over firing it. I closed off the outside air intake to no effect. I then sprayed some water on the wood from a spray bottle, which eventually calmed it down.
No glowing anchor plate or anything like that. Max temp on the collar / pipe was around 260F.
Was I over-reacting, or does this look like I was overfiring it?
Should I generally be safe to pack it full, just avoid overly dry wood?
Is there a way to add a temperature probe to the chimney or the fireplace to get a better idea of what is going on?
