is this good chimney liner pipe???
gsxr1216
13
getting ready to install a newer fireplace insert in my fireplace, the new one uses 6" VS the 8" of my current one.
anyway i did a little surfing on EBAY and found what looks to be like a good deal on 25' of pipe but me being the skeptic when it comes to good prices figured i would make sure this is indeed good pipe at a good deal
(broken link removed)
anyway i was figuring on running a small section of ventinox ovalized SS flexible stove pipe to get up through my damper then have a round to oval adpater to fit the 25' of pipe shown in the link above to run to the top of my chimney.
would this be a good setup and legal??
thanks!
I don't know about the legality of the setup, but the liner kit in the picture is the same TCE kit I bought from a different eBay seller and got a good 316ti kit with Warnack Hersey certification included. Has to be the same one because TCE holds the patent on the cap connector and the tee connector method. I bought mine from these guys and highly recommend them. They will send an insert adapter instead of a tee if you want.
(broken link removed to http://cgi.ebay.com/ws/eBayISAPI.dll?ViewItem&item=260034834318)
Here is the manufacturer's web site.
On my installation in the fireplace I just cut out the damper frame with a hacksaw and went round all the way up. If you go to sell the house and want it to be a fireplace again just pull the liner and put a top mount damper on the chimney for a hundred bucks.
thanks for the info, i would have to measure mine but it looks like it could be a tight fit even without the damper frame?? it would for sure be more cost effective if i could go round the whole way.
how hard is the frame to get out, mine looks like its concreted right into the fireplace brick???
Mine did too. That is why I circled around it for fifteen years. When I finally said the heck with it, it is coming out and started cutting, I found that it was only mortored in on the ends.
I bought Sawzall metal blades and messed with that. I put a metal blade in my sabre saw and messed with that. Finally I just grabbed a hacksaw and it was out of there in nothing flat.
