well since you cant exactly cut these 1ft sections of double walled pellet stoves, if I get a different pellet stove and the height of the outlet for venting is say 4” higher then my last one what will my options be. Thanks
If the vent on the stove is higher then your current exhaust the best option is to move the pipe to the correct height, if it's lower you could build up the hearth.
I assume from the OPs post, he's going straight out from the stove. If the stove outlet and the thimble heights are different... adjustable length pipes won't help.
