McKraut
When you have your storage valves turned off, how often do you have to fill your boiler? How big an area are you heating?A couple things I think are important if you do have storage;
You should have enough storage capacity to carry your heatload for a long enough time to make it worthwhile.Like charging storage once a day or every other day.
You should have a big enough boiler to charge the storage in a reasonable amount of time to fit a persons schedule.
I have only 500gallons,so it won't carry my load to long,but it works nice in the spring and fall.This time of year not so much. The boiler runs pretty much steady,because it's not oversized.
As far as wood consumption goes,not so sure more storage(or any at all)would help me with current sized boiler.
The past few days I have had the storage valves turned off just to see how things go.It does go into idle once and a while,but it doesn't really smoke a lot. I think I use slightly less wood doing it this way.
With the storage turned on,seems like the boiler runs and runs and unless the firebox is kept full,the output is lower and storage temps don't rise with zones steadily calling for heat. With storage off,seems like a load of wood goes a long way. I don't know,maybe it's just me.
I suppose the thing to do would be to weigh the wood loads a week or so each way and compare to heating degree days.
In any event,not sure storage helps too much if the boiler is closely matched to the heatload.
I think the ideal would be modulating output like the pellet boilers,but but you can only turn the air down so far.
Maybe the thing to try would be throttling the output(nozzle size and air)to match demand more so it can run steady with good gasification at different outputs. Probably not as simple as it seems.
Your signature looks like you're heating with an Eko and you have 45,000 gallons of storage. I had to look at that twice.....
![[Hearth.com] Is storage a "must" with a gasifier? [Hearth.com] Is storage a "must" with a gasifier?](https://www.hearth.com/talk/data/attachments/92/92231-ea6f728bc1b6ef9f679384d152d0cbb2.jpg?hash=6m9yi8G275)
