Hi folks.  I have a Morso Owl which is a 7kW stove, so perhaps medium in size, and I mainly burn logs, though I am experimenting with smokeless anthracite briquettes right now as well.
I am wondering whether my stove is under-performing, but I have nothing to measure against.
Problem is this: I find it difficult to get the stove up to temperature (i.e. stovepipe surface temp of ~300F 18" above the stove) - can take as long as an hour to get this far, though occasionally I can do it more quickly - and without 'babying' and regular feeding it goes out quite quickly.
Two examples:
Wood: If I load up with three or four 14" splits, maybe 5" at thickest point (which is around the max I can hold in the firebox) it will need refilling in around two or two and a half hours at the very longest, normally well within an hour and a half. Even with the air down, from very very hot at 11pm it is stone cold by 6am. I read here about overnight burns, and I'm lucky to get a burn long enough to last half that time.
Smokeless fuel: reputed to burn for 18 hours, with air at 3/4 (bearing in mind this is a multi-fuel stove) I left the house at 10am this morning to take my son to his swimming lesson. Inside house temperature was around 16C (60F) which is its current 'unheated ambient' temperature. After a couple of hours from 8am I got the stove going with wood and added coals to get the room temperature to around 20C (68F) before leaving - with around 12 or 15 red hot coals going nicely. Returned at 2pm, the coals have gone cold - no sign of heat, stove has a vague warmth to it but is far from being hot. Room is back at 16C.
I grant you I may be expecting too much of a modest-sized stove, but surely to goodness expecting smokeless briquettes to burn for four hours (when they are rated to at least 12 hours burn-time) isn't too much to ask?
Chimney is ~15m Victorian clay-lined, with 316-grade liner inside into stove (top-exhaust). Room is admittedly slightly bigger and lossier than the stove would prefer - actually three open plan rooms, 16'x14'x12' joined onto 12'x10'x12' onto 12'x12'x7' - but it doesn't explain the poor performance, surely?
Any help appreciated. It was a fairly expensive stove and was professionally installed, chimney was swept less than 8 weeks ago and is not used 24/7, wood is largely dry hardwood (occasional damp bits do find their way into the stove I admit) and it's what you'd call in the US 'EPA style' - i.e. it's super efficient and clean-burning, with primary air (underneath I believe), secondary airwash to the glass, and tertiary 'afterburner' vents to the rear. So, not by any token a 'cheap and nasty' stove.
Thanks,
John
Two examples:
Thanks,
John
